For $20 on Amazon Prime we picked up one of these little USB cameras-
2 Million Pixels Cmos 5m USB Waterproof Hd 6-led Borescope Endoscope Inspection Tube Visual Camera Amazon.com Industrial Scientific - and hooked it up to my Galaxy S3 (USB adapter required.)
And found this-
This is looking in from the outside vent. It fell off right there.
It was cool to look at my teeth from the other side... I need to brush more.That's pretty cool
Hoping the place that comes will open the wall so we can replace it- that is probably 30+ years old.The proper way to fix that is to remove the exterior vent, reach in, pull the flex pipe out, reattach to the exterior vent, replace vent. Shouldn't take more than 5 minutes unless the vent breaks coming out.
They could probably fish a new one without opening the wall if they tried. Not sure they'll try though.Hoping the place that comes will open the wall so we can replace it- that is probably 30+ years old.
It was cool to look at my teeth from the other side... I need to brush more.![]()
Hey- what tape should I use... electrical? masking? scotch?
Needs Flexy tape.
